gyruss
Aug 01, 2020Aspirant
Command or script to reboot Nighthawk M1?
Is there a command or script to reboot the Nighthawk M1 without entering the gui?
icaruspony
Aug 01, 2020Luminary
Perhaps you could modify that script that "turns off data and turns data back on" to do a reboot instead. Of course that script is used to fix certain problems without having to wait for a reboot, so, depending on what you are trying to accomplish, you may be trying to fit a square peg into a round hole instead of using the square hole right next to it.
