guiguilein
Apr 02, 2023Aspirant
Configure LAX20 on French Orange network, help need
Hi everyone, I've been looking across the forum for some help, but I was not able to find anything close to the issue I'm having. Where I leave, Optic fiber is not coming before 2025 at best, ...
michaelkenward
Apr 02, 2023Guru - Experienced User
As the product tag says, the (LAX20) is a 4G LTE WiFi 6 Router.
This section is for Nighthawk with WiFi 6 (AX) and WiFi 6E (AXE) Routers.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Mobile Routers, Hotspots & Modems
Those things are very different from the standard Netgear routers covered in this section.
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
guiguilein
oh sorry for posting in the wrong place.
Can i move the post somehow ? or do i need to repost in the router section ?
