Pridal2008
Jun 24, 2019Aspirant
Connect Nighthawk M1 to Orbi RBR50
Hi there guys, I’m hoping someone may be able to assist. I have the Nighthawk M1 mobile wifi router and the Orbi RBR50 with an Orbi satellite. How do I best connect / setup the connection betwe...
- Jun 24, 2019
Hi Pridal2008 ,
I had a similar setup at home but have since upgraded to the MR2100. There are 3 options that I have used in the past. Option 1 and 2 works best for my setup as Option 3 limits you to 20 connected devices.
Option 1 (Bridge Mode):
- Enable IP Passthrough Mode on the MR1100 (Settings>Setup>Mobile Router Setup). Steps are also detailed in the User Manual.
- Nothing needs to be done on Orbi router side.
Option 2 (DMZ)
- Set a static IP on the Orbi router (i.e 192.168.1.45) - Advanced Settings>Setup>Internet Setup - https://kb.netgear.com/31140/How-do-I-manually-enter-a-static-IP-address-for-my-Orbi-router
- Set the Orbi's static IP as the IP in M1's DMZ (Settings>Advanced Settings>Other - enter 192.168.1.45 into the IP field).
Option 3 (Enable AP mode on Orbi)
- Enable Access Point mode on Orbi Router - https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
I am happy to walk you through it if you are still having issues. Please send me a PM if you require some assistance.
ArodiD
ArodiD
Jun 24, 2019NETGEAR Expert
Hi Pridal2008 ,
Option 2 (DMZ)
ArodiD
