AML1618's avatar
AML1618
Connect R7000P to MR1100
So Frustrating.
R7000P as wireless router to my mobiles,  and computers
R7000P as Wired Router,  through Netgear switched,  to Printer and NAS Storage.
Works 100%,  is Great.
I am connected to the internet through a (Telstra provided) MR1100,  which in and of itself works fine.
How do I connect R7000P to internet through MR1100 ?  I cannot get it to work reliably.
I am using an ethernet cable to join the two devices.
1 Reply
  • Have you tried taking a verified good ethernet cable from the MR1100 to the WAN port on the Router then go into the router settings/config for the WAN section and set it up as DHCP?
    Reboot.
