muhammadali's avatar
muhammadali
Follower
Oct 19, 2020
Connect with main
HELLO, I WOULD LIKE TO HAVE THIS NETGEAR NIGHTHAWK M2 CONNECTED PERMANENTLY TO THE POWER SUPPLY? ALSO CAN I HAVE THE BATTERY FITTED IN CASE OF POWER FAILURE? THANK YOU.
  • Blanca_O's avatar
    Oct 19, 2020
    Hi muhammadali
    Welcome to NETGEAR Community!
    If you plan to run the device 24/7, we suggest you to power the device with the PA only without inserting battery. This way, it will avoid the battery from getting hot and impacting the device's performance.
    Blanca
    Community Team
