butterflyfish
Oct 26, 2022Follower
Connect XVR IP camera system with Nighthawk MR2100 M2
I have a XVR camera system (herospeed.net) that I could successfully install locally and by wiring the XVR to the router with an ethernet cable and port forwarding. However, I cannot manage to access it remotely.
I have tried using P2P, UPnP and DDNS without any luck.
I would like to know if it is actually possible and compatible to install the XVR with the Nighthawk MR2100 for remote access and if it is, which protocol should I use?
Any help most welcome, I am losing my mind with this!
No RepliesBe the first to reply
