gms63
Sep 12, 2020Follower
Connected No Internet
My NightHawk Mobile Router was working fine a few days ago. Now, I just get "No internet, secured" as the message on all my computers when I try to connect. The firmware version is Nighthawk M...
Blanca_O
Oct 05, 2020NETGEAR Employee Retired
Hi gms63
Welcome to NETGEAR Community!
If you are connected to the mobile router but cannot connect to the Internet, try the following suggestions:
• Check the display status on the LCD.
• Make sure that network coverage is available in your area.
• Make sure that your SIM card is active and enabled with data services.
• Wait one to two minutes for the mobile router to initialize.
• Confirm that your account is activated and that no other Internet connections are active.
• Switch your mobile router off and on and restart your computer or WiFi device.
Blanca
Community Team
