RikyRomei
Aug 14, 2019Aspirant
Connectin a NAS to my NightHawk
Hello, I would like to connect my NAS WD MyCloud EX2 with Ethernet. So when I'm travelling I can read/write to it. My current - and test - configuration is: 1. NAS connected to my ADSL/Fibre ro...
JSchnee21
Aug 14, 2019Virtuoso
Google Cloud or Amazon Drive are likely the simplest solution. I get 2TB from Google for $199 / year.
You can also connect a USB thumbdrive or USB connected external HD directly to the MR1100
Are you trying to stream movies or something without using your cellular data? Are you sharing across multiple computers? (aka why not just connect the thumbdrive/drive to your PC?)
