DNMiller
Sep 30, 2022Follower
Connecting Aircard MIMO antenna to Verison Jetpack
I have a Verison MIFI Jetpack for 4GLTE, it has only one TS9 connection. The MIMO Aircard part no 6000450 I bought recently has 2 TS9 cables.
Are they compatible? How can I make them work together?
1 Reply
Is this a Netgear Aircard device? That's not a model number, but this isn't the best place for help with these devices.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Mobile Routers, Hotspots & Modems
Those things are very different from the standard Netgear routers covered in this section.
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
