Barwon's avatar
Barwon
Tutor
Jun 02, 2017
Connecting Arlo base station to Nighthawk?
Can I connect my Arlo base station connect to Nighthawk M1 Ethernet port?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Barwon
    You should be able to the arlo base station needs a internet connection if you meet the required speed should be fine.
    DarrenM
