gman2's avatar
gman2
Connecting my N300 to CCTV DVR using a ethernet cable ... using my samsung mobile as hotspot
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi gman2
    Welcome to NETGEAR Community!
    What is the model number of your NETGEAR device?
    May we please know what you are trying to achieve?
    Kindly describe your network setup.
    Blanca
    Community Team
    • gman2's avatar
      gman2
      TKS Bianca,     MODEL WN3000RP-100AUS  it connects to all wifi equipped appliances no problem, but my Swann CCTV must be connected by ethernet cable [ no wifi ]. when connecting via ethernet cable there is no connection. As I don't have a router I use my hotspot for data transfer.  Graeme
      • Blanca_O's avatar
        Blanca_O
        Hi gman2
        Please describe the LED status of the extender. Can you please wired a different device / computer to the extender to test the connection?
        Blanca
        Community Team
