Retired_Member
May 15, 2019Connecting NETGEAR MIMO Antenna ruined by 4G modem
I was getting good speeds on my NETGEAR 4g modem LB1120, but wasn’t getting full bars so I tried an antenna as instructions suggested, plugged in a MIMO NETGEAR connecter and it ruined everything some...
- Retired_MemberMay 16, 2019I was able to fix this by changing around some DNS/ IP4 instead of IP 4/6, back to 4g lite
Retired_Member
schumaku
May 17, 2019Guru - Experienced User
The antenna did't changed the router config of course.
