maccamenzies
May 10, 2017Follower
Connecting Nighthawk M1 to Linksys X3500 wireless router problems
Having problems and hope someone can point me in the right direction.
Im trying to connect the M1 to my wireless router Linksys X3500 so that i can increase the wireless range.
Can anyone point me in the right direction or recommend some settings to change
Many thanks
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello maccamenzies
You may want to set your linksys router as a access point you will have to look for that setting in the router.
DarrenM
