macca_mm
Jul 11, 2022Follower
Connecting to internet via ethernet port on Nighthawk M2
Hi all, New to this discussion space. I have a Telstra Nighthawk M2 (2100) which will allow me to connect my desktop to the internet using the ethernet port BUT will not connect another device (C...
Jul 11, 2022Guru - Experienced User
Did you connect the M2 to a switch? or another router? (so you can connect more than 1 device)
Is the M2 in passthrough mode or still in router mode?
Are you still able to connect wireless devices to it?
