Japi's avatar
Japi
Initiate
Aug 12, 2019
Connection to SMART TV : FINLUX 22FFMD5620 22" SMART TV 12V
HI, I have my M1 Mobile router and I can connect to it by my PC and iPhone etc. but I can't do it with my Smart TV in my mobile home (where the TV located).  TV is FINLUX 22FFMD5620 22" SMART TV 12V....
  • Japi's avatar
    Japi
    Aug 21, 2019
    Hi Blanca,
    Yes the Finlux SMART TV detect the network but when I connect to this it not go thru. It try but no connection. Same happen by WPS. Sometimes it show the network name but it not work by using WPS.
    Yes it works with other routers and now I use it by iPhone X connection point.
    I hear from the Finlux that the wifi module is 1-channel module and it can receive 25M connection. I have my defined operation speed 600M. Can Netgear still handled this the communication? ..or is it too fast?
    Is it so that it not works if the IP address is static or what ou mean with this?
    BR
    Jarmo
