Landrew
Dec 17, 2019Follower
Considering Router and modem upgrade but want to try mode change first
Hi - Really starting at basics - I am considering a new router and perhaps modem as I have not upgraded either in years. I do need to upgrade my firmware, but can I simply change the mode from 56 Mbp...
Dec 17, 2019Guru - Experienced User
You can make that change without much issues.
but you're correct in that you need an upgrade. If you're streaming 4k, I'd recommend upgrade to at least something with 5ghz for higher throughput
