metznerj
Jan 21, 2019Follower
Cradle for Nighthawk M1
Hi all,
I have a quick question, does anyone know if Netgear will be producing a Cradle for the Nighthawk M1 mobile router similar to the Netgear DC112A they made for their Air Cards? Thank you in ...
AUdd
Feb 15, 2019Aspirant
And they hobbled the ethernet port on it so you can plug it into an regular wifi routers ethernet port and extend its wireless.
400$ for something that can't be used for something as basic as integrating with your existing router.
the_real_KOSH
Jan 04, 2020Star
- the_real_KOSHJan 06, 2020Star
The Perspex plate stabilises the external aerials for 4x4 external MIMO without drilling a Hole
