Abhayadevs
Jan 31, 2018Aspirant
D6000 connection problems
Hello, I am using D6000 router and I am unable to connect to some selected https urls - https://infydrive.infosys.com I tried upgrading to the latest firmware.l but it didn't help. With another rou...
- Feb 07, 2018
Hi Abhayadevs,
If your set up is working for you then I wouldn't reset it. If you decide to update your firmware and have any issues. Please do a factory reset.
Let me know what you decide to do :]
- Jason N
JasonN
Feb 01, 2018NETGEAR Employee Retired
Hi Abhayadevs,
Sorry to hear about your connection issues.
Did you reset the router to factory settings after the firmware update?
New firmware sometimes introduces changes that are not compatible with the old configuration.
What firmware are you on?
Please keep me updated. :]
- Jason N
