Abhayadevs
Jan 31, 2018Aspirant
D6000 connection problems
Hello, I am using D6000 router and I am unable to connect to some selected https urls - https://infydrive.infosys.com I tried upgrading to the latest firmware.l but it didn't help. With another rou...
- Feb 07, 2018
Hi Abhayadevs,
If your set up is working for you then I wouldn't reset it. If you decide to update your firmware and have any issues. Please do a factory reset.
Let me know what you decide to do :]
- Jason N
Abhayadevs
Feb 06, 2018Aspirant
Hello,
Thanks for responding.
My firmware is V1.0.0.68_1.0.1
And there is an update. The issue is only if I am using the DSL. When I used an ISP provided modem and used the WAN interfere I am able to connect to the URLs.
Do you still think I need to reset the router?
Thanks an regards,
Abhayadev.
Thanks an regards,
Abhayadev.
JasonN
Feb 07, 2018NETGEAR Employee Retired
Hi Abhayadevs,
- Jason N
- AbhayadevsFeb 07, 2018AspirantIn fact it's not working now!
I used a temporary setup to test it and found working via WAN but I need it to be working over DSL which is not happening for me now.
Should I try factory resetting?
Thanks.- JasonNFeb 07, 2018NETGEAR Employee Retired
Hi Abhayadevs,
Yes, please perform a factory reset after the update. Thank you.
- Jason N
- AbhayadevsFeb 09, 2018AspirantHi,
I do the factory resetting and bingo it worked out and now I am able to access the mentioned URLs.
Thanks a lot for the support.
So lesson learned is to do the factory resetting after every firmware upgrade.
Once again thanks for the support.
Regards
Abhayadev S.
