Abhayadevs
Jan 31, 2018Aspirant
D6000 connection problems
Hello, I am using D6000 router and I am unable to connect to some selected https urls - https://infydrive.infosys.com I tried upgrading to the latest firmware.l but it didn't help. With another rou...
- Feb 07, 2018
Hi Abhayadevs,
If your set up is working for you then I wouldn't reset it. If you decide to update your firmware and have any issues. Please do a factory reset.
Let me know what you decide to do :]
- Jason N
JasonN
Feb 07, 2018NETGEAR Employee Retired
Hi Abhayadevs,
Yes, please perform a factory reset after the update. Thank you.
- Jason N
Abhayadevs
Feb 10, 2018Aspirant
Hi,
I do the factory resetting and bingo it worked out and now I am able to access the mentioned URLs.
Thanks a lot for the support.
So lesson learned is to do the factory resetting after every firmware upgrade.
Once again thanks for the support.
Regards
Abhayadev S.
Regards
Abhayadev S.
- JasonNFeb 13, 2018NETGEAR Employee Retired
Hi Abhayadevs,
I'm glad it fixed your problem! Yes, it is always good to do a factory reset after a firmware update so it can flush out the old configurations/bugs.
Thanks for choosing NETGEAR. :]
- Jason N
- AbhayadevsFeb 13, 2018Aspirantđ
Thank you.
