cdfr31
Sep 02, 2021Tutor
Data connection interrupted on a Nighthawk M5
Hi,
I've bought a Nighthawk M5 5G (MR5200) and I've suscribed to a orange unlimited 5G plan with a dual sim.
When I use my sim card in the hotspot M5 that doesn't work. I have a message saying data connection interrupted. I've correctly setup the apn I think. I've unactivated the pin code authentification as it was suggested in another thread.
I've attached few screenshots below. I hope someone can help me. I struggle with Orange hotline and they are really awfully useless in solving anything.
Best regards,
Frederic
1 Reply
- JohnPengNETGEAR Expert
Please select Auto instead of LTE and 5GNR to make sure you can get on LTE connection first.
You can provide a model.json after connecting to LTE. You can send me a private message with the model.json file.
- Logon to the webui (http://192.168.1.1 ) as an administrator
- Navigate to URL http://192.168.1.1/model.json via the same browser window
- Capture the results (by selecting all + copy) and send it back
