rcoble
Feb 05, 2020Tutor
Data display on AirCard 810S Mobile
i have had this device for quite awhile, and never had an issue, recently i had issues with accessing my telstra account online, and needed to change from IE to Chrome, as well as change passwords,,,...
- Mar 05, 2020
Sorry for the inconvinence. We did submit the fix to Telstra a month ago for Telstra approval. But the testing was delayed in Telstra lab.
Thanks
John
JohnPeng
Feb 05, 2020NETGEAR Expert
Telstra updated its data usage server and caused the issue for most of the devices. An update is going through Telstra testing. Hope we can release the update in the next couple of weeks.
Thanks
rcoble
Feb 07, 2020Tutor
thank you JohnPeng for your reply,,, i will keep a check on it and be abit more patient,,,
