rcoble
Feb 05, 2020Tutor
Data display on AirCard 810S Mobile
i have had this device for quite awhile, and never had an issue, recently i had issues with accessing my telstra account online, and needed to change from IE to Chrome, as well as change passwords,,,...
- Mar 05, 2020
Sorry for the inconvinence. We did submit the fix to Telstra a month ago for Telstra approval. But the testing was delayed in Telstra lab.
Thanks
John
JohnPeng
Feb 05, 2020NETGEAR Expert
Telstra updated its data usage server and caused the issue for most of the devices. An update is going through Telstra testing. Hope we can release the update in the next couple of weeks.
Thanks
rcoble
Mar 02, 2020Tutor
hi again,,, has there been any movement on the problem,,, my device still only showing "detecting service"..... quite annoying not seeing the information and having to log into the computer, any updates ????????
- JohnPengMar 05, 2020NETGEAR Expert
Thanks
John
- JohnPengMar 10, 2020NETGEAR Expert
Telstra approved the new release for AC810S to address the data usage display issue. You have posted the update online.
You can do a manual upgrade check to upgrade to the latest release. After upgrade, please do a factory reset if the data usage display can't be retored automatically.
Thanks
- rcobleMar 10, 2020Tutor
Did it manually,,,, all fixed,,, thank you again
