nicola_d's avatar
nicola_d
Follower
Aug 14, 2023
Data off load vs Load Balance
Dears,
I would like to understand if the "data offload" feature can be used to act as a load balance procedure. Does the offloading kick in only when the MR1100 is experiencing bad connection, or I can actually use it as load balancer regardless connection quality?
Thx!
Nicola
1 Reply
  • JohnPeng's avatar
    JohnPeng
    NETGEAR Expert
    nicola_d wrote:
    Dears,
    Thx!
    Nicola
    Data offloading is not related to load balance. Offloading is to save your wireless data usage when there are other broadbands available and can be used.
    When the network the device is offloaded to is down, the data connection can be revert back to wireless data to keep the data connection on. This feature is called Failover.
    Thanks
