Dougal_McBear
Jun 17, 2019Aspirant
Data Offloading M2
Hi This is about a Nighthawk M2 but only M1 shows in list. I have only 80GB allowance per month and I am using WiFi offloading through my mobile. Even with 20MBPS with the phone, the router still d...
- Jun 23, 2019
Hi Dougal_McBear,
What you could try is to disable cellular data so that if it ever fell back to LTE modem from Offload it would not use any data. Log into the WebUI then Settings>Advanced Settings>Cellular - Uncheck cellular data and hit apply.
Other option is to remove the SIM card.
ArodiD
ArodiD
Jun 23, 2019NETGEAR Expert
Hi Dougal_McBear,
ArodiD
- Dougal_McBearJun 23, 2019Aspirant
Thanks ArodiD
I had a "derrr..." moment as soon as I posted that. Remove the SIM! Obvious really.
A bit tedious so I will try the cellular setting as you suggest.
Doug
