Markj888's avatar
Markj888
Follower
Oct 18, 2021
Data Roaming Disconnected
Hello
Just arrived from the UK to Belgium and my M2 said the data roaming is disconnected
I cannot put the app on my phone as the M2 is not working so is there any other way of changing the roaming settings to international.
thanks.
1 Reply
  • JohnPeng's avatar
    JohnPeng
    NETGEAR Expert
    You can use Touch UI to access the setting to enable roaming data.
