Gidget21
Aug 22, 2022Tutor
Data usage info unavailable at this time Nighthawk M2 MR2100
Hi, I have had no data usage info showing on my Nighthawk M2 for the last couple of months. I have spent a total of eight hours online to Telstra over the past few days with no resolution. I'm pret...
Buckelew92110
Aug 23, 2022Aspirant
Hello,
There are no issues with data usage that Netgear are aware of.
Can you try rebooting the device to see if it comes back or do a factory reset on the unit.
Has there been any recent changes to your data plan?
Please also make sure the firmware is upto date by tapping Settings>Software>Check fo updates
- Gidget21Aug 23, 2022Tutor
Hi, I have done all of those things several times and it has made no difference.
No recent changes to my plan that I am aware of.Thanks
- Gidget21Aug 30, 2022Tutor
Is anyone able to help me? This is so frustrating!
- Blanca_OSep 04, 2022NETGEAR Employee Retired
Hi Gidget21,
Please provide the device SKU (e.g. MR2100-1TLAUS).
Kindly get in touch with Telstra and have them double check to ensure that device reached the billing server.Regards,
Blanca
Community Team- Gidget21Sep 04, 2022Tutor
Hi Bianca,
I have been in touch with Telstra and they just refuse to help. They say it is a Netgear issue and is nothing to do with them.
I will try again to give them this number MR2100-1TLAUS_04.02.181.00 but they just keep telling me to contact Netgear.
Thanks
