Gidget21
Aug 22, 2022Tutor
Data usage info unavailable at this time Nighthawk M2 MR2100
Hi, I have had no data usage info showing on my Nighthawk M2 for the last couple of months. I have spent a total of eight hours online to Telstra over the past few days with no resolution. I'm pret...
Buckelew92110
Aug 23, 2022Aspirant
Hello,
There are no issues with data usage that Netgear are aware of.
Can you try rebooting the device to see if it comes back or do a factory reset on the unit.
Has there been any recent changes to your data plan?
Please also make sure the firmware is upto date by tapping Settings>Software>Check fo updates
Gidget21
Aug 23, 2022Tutor
Hi, I have done all of those things several times and it has made no difference.
No recent changes to my plan that I am aware of.
Thanks
