ds21
Mar 04, 2021Follower
Data Usage Info Unavailable
A couple of weeks ago I bought a Nighthawk M5 and the data usage was displayed on the screen and last week it just suddenly stopped showing it. Instead it reads 'Data Usage Info Unavailable'. What c...
ArodiD
Mar 04, 2021NETGEAR Expert
Hi ds21 ,
If you are using your M5 on the Telstra network then there is a current known outage which is being investigated with high priority.
Arodi
- ArodiDMar 10, 2021NETGEAR Expert
Hi All,
This issue has now been resolved for anyone using a Telstra SIM.
Arodi
- Trev_CJul 25, 2022AspirantHi there,
Any idea how they fixed this?
I bought an M5 from Telstra a few weeks ago and same issue, it was working showing the data usage however now it is not.
Thanks again,
Trev
