Main_Tag
Mar 10, 2025Guide
Data Usage netgear nighthawk m3 mh3150
Hello, I bought a netgear nighthawk m3 mh3150 last month. Is there an option to show the data usage on the screen of the router or will this feature implemented? Best regards
Mar 12, 2025Guru - Experienced User
Page 45 of the manual goes over viewing data usage.
https://www.downloads.netgear.com/files/GDC/MH3150/MH3150_UM_EN.pdf
Main_Tag
Mar 12, 2025Guide
I'm sorry but the manual is referring only to the web interface while I had been interested in the display on the device. Could you please inform me how to show the data usage on said display?
- plemansMar 12, 2025Guru - Experienced User
I don't have one so i can't play with it to tell you if there's another option.
- rcpaxMar 15, 2025Luminary
Main_Tag wrote:
I'm sorry but the manual is referring only to the web interface while I had been interested in the display on the device. Could you please inform me how to show the data usage on said display?It seems you can't directly see usage on the LCD. This M3 is comparable to an MR6150, but with a different UI. Interesting product. Did not have time to compare bands, but the band list seems comparable to the MR6150 as well, but the M3 is missing the 2.5Gb RJ-45 port found in the M6 models.
- Main_TagMar 17, 2025GuideThank you for your help and i hope that this might be implemented later
