Main_Tag
Mar 10, 2025Guide
Data Usage netgear nighthawk m3 mh3150
Hello, I bought a netgear nighthawk m3 mh3150 last month. Is there an option to show the data usage on the screen of the router or will this feature implemented? Best regards
Main_Tag
Mar 12, 2025Guide
I'm sorry but the manual is referring only to the web interface while I had been interested in the display on the device. Could you please inform me how to show the data usage on said display?
Mar 12, 2025Guru - Experienced User
I don't have one so i can't play with it to tell you if there's another option.
