PPolly
Aug 11, 2019Tutor
Data Usage Nighthawk M1 again
Have updated my router and it is now showing "detecting service" instead of data usage. I had installed version 12.06.02.00 I know this has been a problem in the past but the prior solution is now o...
IrvSp
Aug 12, 2019Master
You are in the wrong forum. This is a Netgear Nighthawk Wireless Router forum. Go back to Community, then select HOME, and chose which fits your problem. Can't even tell you which to use as the subject mentions M1 and the footer is completely different. None are Nighthawk wireless routers.
