PPolly
Aug 11, 2019Tutor
Data Usage Nighthawk M1 again
Have updated my router and it is now showing "detecting service" instead of data usage. I had installed version 12.06.02.00 I know this has been a problem in the past but the prior solution is now o...
Blanca_O
Aug 13, 2019NETGEAR Employee Retired
Hi PPolly
Welcome to NETGEAR Community!
Can you please confirm first the model number of your NETGEAR device? Do you have a ADSL modem/router?
Blanca
Community Team
- PPollyAug 14, 2019Tutor
Hi Bianca, I have a DGND3700v1, wireless nighthawk ist model
- PPollyAug 21, 2019Tutor
Sorry, confused my two netgear routers, the mobile nighthawk M1 is the one I am having trouble with even though I have updated with the latest Telstra firmware patch
- michaelkenwardAug 22, 2019Guru - Experienced User
That's one of the Mobile Routers, Hotspots & Modems. You might get better and quicker replies, and find other answers, over in the appropriate section:
