BobHx
Aug 18, 2019Aspirant
DC112A Failed to update GUI language file
I'm currently using the DC112A with the WAN port connected to a satellite modem (high latency connection - ping time 600 - 700 ms) Netgear Genie shows my current Firmware version is V1.0.0.32_1.0.60...
Blanca_O
Sep 10, 2019NETGEAR Employee Retired
Hi BobHx
Please try again the firmware update and let us know of the result. This should be fixed by now.
Blanca
Community Team
- BobHxSep 10, 2019Aspirant
Hi Bianca - that's fixed it: many thanks, Bob
- Blanca_OSep 10, 2019NETGEAR Employee Retired
Hi BobHx
Great! Thank you for the update and glad to know that it is now working.
Blanca
Community Team- Red_SquirrelSep 19, 2019Aspirant
Hello Everyone,
I'm also suffering the same problem...
A new version has been found. Do You want to upgrade to the new version now?
Current GUI Language Version: 1.0.0.18_2.1.38.3
New GUI Language Version: 1.0.0.44_2.1.38.3
Current Firmware Version 1.0.0.18
New Firmware Version 1.0.0.44_1.0.60
When I click YES, I get the GUI failure.
- caribicaSep 24, 2019Aspirant
DC112A-100EUS same issue never resolved, any advice?
