BobHx
Aug 18, 2019Aspirant
DC112A Failed to update GUI language file
I'm currently using the DC112A with the WAN port connected to a satellite modem (high latency connection - ping time 600 - 700 ms) Netgear Genie shows my current Firmware version is V1.0.0.32_1.0.60...
Blanca_O
Sep 10, 2019NETGEAR Employee Retired
Hi BobHx
Please try again the firmware update and let us know of the result. This should be fixed by now.
Blanca
Community Team
BobHx
Sep 10, 2019Aspirant
Hi Bianca - that's fixed it: many thanks, Bob
- Blanca_OSep 10, 2019NETGEAR Employee Retired
Hi BobHx
Great! Thank you for the update and glad to know that it is now working.
Blanca
Community Team- Red_SquirrelSep 19, 2019Aspirant
Hello Everyone,
I'm also suffering the same problem...
A new version has been found. Do You want to upgrade to the new version now?
Current GUI Language Version: 1.0.0.18_2.1.38.3
New GUI Language Version: 1.0.0.44_2.1.38.3
Current Firmware Version 1.0.0.18
New Firmware Version 1.0.0.44_1.0.60
When I click YES, I get the GUI failure.
SKU: DC112A-100EUS
