BobHx
Aug 18, 2019Aspirant
DC112A Failed to update GUI language file
I'm currently using the DC112A with the WAN port connected to a satellite modem (high latency connection - ping time 600 - 700 ms) Netgear Genie shows my current Firmware version is V1.0.0.32_1.0.60...
BobHx
Sep 10, 2019Aspirant
Hi Bianca - that's fixed it: many thanks, Bob
Blanca_O
Sep 10, 2019NETGEAR Employee Retired
Hi BobHx
Great! Thank you for the update and glad to know that it is now working.
Blanca
Community Team
- Red_SquirrelSep 19, 2019Aspirant
Hello Everyone,
I'm also suffering the same problem...
A new version has been found. Do You want to upgrade to the new version now?
Current GUI Language Version: 1.0.0.18_2.1.38.3
New GUI Language Version: 1.0.0.44_2.1.38.3
Current Firmware Version 1.0.0.18
New Firmware Version 1.0.0.44_1.0.60
When I click YES, I get the GUI failure.
SKU: DC112A-100EUS
- ab2019Sep 28, 2019Aspirant
Same problem
SKU: DC112A-100EUS
ab2019 wrote:Same problem
SKU: DC112A-100EUS
Some additinal weirdness, version reported below logout button:
Firmware Version
V1.0.0.18_1.0.60
