BobHx
Aug 18, 2019Aspirant
DC112A Failed to update GUI language file
I'm currently using the DC112A with the WAN port connected to a satellite modem (high latency connection - ping time 600 - 700 ms) Netgear Genie shows my current Firmware version is V1.0.0.32_1.0.60...
UC74
Sep 10, 2019Guide
I have the same problem.
I tried to update the firmware.
It indicates that a new update is available. When I choose to update, it comes to the stage where it updates the language file and fails.
I tried also with genie sw (for window pc): it failed too.
Can you give us a link to the firmware file please?
Blanca_O
Sep 17, 2019NETGEAR Employee Retired
Hi, All,
May I please have the device SKU? It can be checked on their end by checking the box of the product, on the barcode label, which should indicate DC112A-xxxxxx.
Blanca
Community Team
