BobHx
Aug 18, 2019Aspirant
DC112A Failed to update GUI language file
I'm currently using the DC112A with the WAN port connected to a satellite modem (high latency connection - ping time 600 - 700 ms) Netgear Genie shows my current Firmware version is V1.0.0.32_1.0.60...
Blanca_O
Sep 17, 2019NETGEAR Employee Retired
Hi, All,
May I please have the device SKU? It can be checked on their end by checking the box of the product, on the barcode label, which should indicate DC112A-xxxxxx.
Blanca
Community Team
BobHx
Sep 17, 2019Aspirant
Hi Blanca - mine is DC112A-1TLAUS - working well thanks
Bob
- Blanca_OSep 18, 2019NETGEAR Employee Retired
Hi, All,
Thank you for providing your device's SKU. I am checking this with our engineers. I will provide update once new information will be available
Blanca
Community Team
