BobHx
Aug 18, 2019Aspirant
DC112A Failed to update GUI language file
I'm currently using the DC112A with the WAN port connected to a satellite modem (high latency connection - ping time 600 - 700 ms) Netgear Genie shows my current Firmware version is V1.0.0.32_1.0.60...
pierrejn
Oct 08, 2019Initiate
Hello, I try many times to updrade to the new firmware and it is always the same message as you have, but in french and the upgrade failed with the same problem. I hope that Netgear will provide us a solution quickly now. May be if we have the new language pack and firmware we can upgrade by ourselves.
Version actuelle de la langue de l'interface graphique: 1.0.0.18_2.1.38.3
Nouvelle version de la langue de l'interface: 1.0.0.44_2.1.38.3
Version actuelle du micrologiciel (firmware) 1.0.0.34
Nouvelle version du micrologiciel (firmware) 1.0.0.44_1.0.60
Notes sur la version: 1. [Bug Fix] Fixed security issue. 2. [Bug Fix] Fixed security issue.
SWE_Gardis
Oct 08, 2019Star
We are all Netgear customers and the company treats us like crap.
Our company will never buy a product again from Netgear.
