BobHx's avatar
BobHx
DC112A Failed to update GUI language file
I'm currently using the DC112A with the WAN port connected to a satellite modem (high latency connection - ping time 600 - 700 ms) Netgear Genie shows my current Firmware version is V1.0.0.32_1.0.60...
  • Blanca_O's avatar
    Sep 10, 2019
    Hi BobHx
    Please try again the firmware update and let us know of the result. This should be fixed by now.
    Blanca
    Community Team
