Visserd
Aug 21, 2019Aspirant
DC112A firmware update fails
I tried to update firmware on my Dc112A. It says there is a new update available. When I select to update it gets to the stage where it is updating language file and fails. I have tried resetting mod...
caribica
Sep 16, 2019Aspirant
nothing works same issue here, what is the fix or workaround, can somebody upload a manual firmware update?
Blanca_O
Sep 17, 2019NETGEAR Employee Retired
Hi, All,
May I please have the device SKU? It can be checked on their end by checking the box of the product, on the barcode label, which should indicate DC112A-xxxxxx.
Blanca
Community Team
- UC74Sep 17, 2019GuideHi Bianca,
SKU is DC112A-100EUS - manu12Sep 18, 2019Aspirant
Hello Blanca,
My SKU is DC112A-100EUS.
I also tried to make the update through the Netgear Genie Windows app, but with the same result.
Cheers.
Emmanuel
- BINAUSep 23, 2019Star
Blanca_O any update on this? This issue has been reported over 30 days ago and most of us are still yet to see some solution. Thats 30+ days were running without the latest security fixes. As a seasoned software developer, I can assure you it does not take anywhere nears that amount of time to plug a install bug or patch the firmware.
Come on NetGear, Its about time you come to the party now.- SWE_GardisSep 23, 2019StarI couldn't have written it better myself!
Agree to 100%.- BINAUSep 30, 2019Star
Still not even a peep from NetGear? What kind oif supprt do you call this? Giving us a run around for months.
