Visserd
Aug 21, 2019Aspirant
DC112A firmware update fails
I tried to update firmware on my Dc112A. It says there is a new update available. When I select to update it gets to the stage where it is updating language file and fails. I have tried resetting mod...
yoyojpg
Oct 10, 2019Tutor
Oyé Oyé!
Warning!! Here, the firmware is available.
I put you the link to download.
http://www.downloads.netgear.com/files/GDC/DC112A/DC112A_V1.0.0.44_1.0.60.zip
You will need to unzip it in a folder (on the desktop for example to have it at hand)
For installation, go to "Smart Cradle"> Management / then click on the tab "ADVANCED" / then "Administration" / then "Update Router".
Then select the file "DC112A-V1.0.0.44_1.0.60.chk" and OK
The router will restart. Internet will cut itself.
The key will restart.
If no change and the firmware number remains unchanged, try again.
The key may alert you (1). Do not panic, go to settings and reset. She will ask you again, click on it and leave it to connect.
Restart your PC to fix everything here and there!
It took a while but we got there.
Thank you all for your perseverance. It has to pay!
Good continuation.
Yohann
cliffmstone
Mar 31, 2020Tutor
Hi. I have tried these steps and all I get is that the file is incorrect
Thanks
