Shannon333
Mar 13, 2020Star
DC112A Firmware Update fails
Hi, My DC112A has a firmware update available (V1.0.0.44_1.0.60) I'm currently running V1.0.0.42_1.0.60. Hardware Version DC112A V1.0 Firmware Version V1.0.0.42_1.0.60 ...
cliffmstone
Mar 31, 2020Tutor
I have exactly the same problem. Download the correct formware, device says update availabe and yet cannot find automatically. Try the manul aupdate method and I am told the file is incorrect. The file suffix is .chk.
- Shannon333Jul 19, 2020Star
Seems netgear doesn't care.
We are now up to 1.0.0.46 Hotfix and the SKU still isn't supported
- QwackersAug 08, 2020Initiate
Ditto Shannon333 comments - seems Netgear does not care about the Australian SKU of the DC112A - Netgear have released a number of releases where the AU model isn't supported currently stuck on Firmware Version V1.0.0.42_1.0.60. I'd love to see a resolution to this and move to close the known security flaws patched in Firmware Version 1.0.0.48.
- sgrubySep 21, 2020Tutor
I got a used DC112A-2RDMES (I'm in the US) and the latest update is 1.0.0.42, but I can't find the download file and the update in the GUI doesn't download the update. Is there anything that can be done to get the firmware update?
