SoCalGallon
Sep 30, 2024Tutor
Dead Netgear Nighthawk MR6550 (AXE3600)
We purchased the MR6500 Nighthawk in August 2023. 1 Year warranty is expired and device is dead. Will not charge or turn on. Have tried multiple USB cords and charging ports. THe product just seemed ...
- Oct 01, 2024
have you tried connecting it without the battery?
Also, make sure your charging and cable are of high enough quality if you're trying others. The newer devices pull more power and you need decent ones of both.
SoCalGallon
Oct 01, 2024Tutor
Thanks for your input. The device won't run either when plugged in with the included USB and AC-USB connector or on battery (which is dead).
What I really want to find out is whether I can send it to Netgear and pary to have it repaired. It is a $1K paperweight right now. It is out of warranty but if I can pay a couple hundred bucks to be repaired it is better than tossing it.
Oct 01, 2024Guru - Experienced User
Try a non-stock charger and cable. I've seen the stock ones not supply enough power or have a bad cable.
Again, ensure its a high quality cable and meets the minimum charger qualifications. I've got a 65w and 140w that I used for quick charging my laptop that I use with my MR6150 when its left on 24/7
- SoCalGallonOct 01, 2024Tutor
Thank you. We had tried multiple chargers. Nothing works. What I really want to do is pay to have Netgear repair the very $$$ device that lasted just over one year. I cannot figure out how to do this.
