MajorWebUser's avatar
MajorWebUser
Definition of Mobile > Status Details > 4G Details
I would like to find a list of definitions for all of the items shown under 4G Detials in the Mobile > Status Details of the NETGEAR browser dashboard.
I'd also appreciate a description of how good or bad those items that have ranges are. For example, RSRP (dBm) >-84 is excellent, -85 to -102 good, -103 to -111 fair, < -112 poor.
Thanks — Major
  • Ditto.  I'm using an LB2120, but I'm sure it's the same issue. Interperting the   status details   should   not   have to become a research   project   for users.   Still   looking   for   a   list   of   definitions,   all   in    one    place.    If I   find   it,   I'll    post    it   here,   as   I   hope   you   will.   Good   luck!!! .... Ron
  • I don't know alot but I do know the RSRQ is an important factor as well. I can get a -90 RSRP on B12 and -110 RSRP on B4. The nighthawk wants to stay on B4 even with the worse signal because the RSRQ is -7 to -10, whereas the RSRQ on B4 is -10 to -12. The RSRQ is the quality of the signal.
    • jpr78's avatar
      jpr78
      Tutor
      ^^ TYPO ABOVE
      Original: The nighthawk wants to stay on B4 even with the worse signal because the RSRQ is -7 to -10, whereas the RSRQ on B4 is -10 to -12. The RSRQ is the quality of the signal.
      Corrected: The nighthawk wants to stay on B4 even with the worse signal because the RSRQ is -7 to -10, whereas the RSRQ on B12 is -10 to -12. The RSRQ is the quality of the signal.
