MajorWebUser
Feb 10, 2018Aspirant
Definition of Mobile > Status Details > 4G Details
I would like to find a list of definitions for all of the items shown under 4G Detials in the Mobile > Status Details of the NETGEAR browser dashboard.
I'd also appreciate a description of how good or bad those items that have ranges are. For example, RSRP (dBm) >-84 is excellent, -85 to -102 good, -103 to -111 fair, < -112 poor.
Thanks — Major
- jpr78Tutor
I don't know alot but I do know the RSRQ is an important factor as well. I can get a -90 RSRP on B12 and -110 RSRP on B4. The nighthawk wants to stay on B4 even with the worse signal because the RSRQ is -7 to -10, whereas the RSRQ on B4 is -10 to -12. The RSRQ is the quality of the signal.
- jpr78Tutor
^^ TYPO ABOVE
Original: The nighthawk wants to stay on B4 even with the worse signal because the RSRQ is -7 to -10, whereas the RSRQ on B4 is -10 to -12. The RSRQ is the quality of the signal.
Corrected: The nighthawk wants to stay on B4 even with the worse signal because the RSRQ is -7 to -10, whereas the RSRQ on B12 is -10 to -12. The RSRQ is the quality of the signal.
- RonOnThePondAspirant
Ditto. I'm using an LB2120, but I'm sure it's the same issue. Interperting the status details should not have to become a research project for users. Still looking for a list of definitions, all in one place. If I find it, I'll post it here, as I hope you will. Good luck!!! .... Ron
