Khaled88's avatar
Khaled88
Follower
Jun 08, 2020
Device Unlock Netgear Nighthawk Mr1100
Hey, I have a Netgear MR1100 formatted and then the device is locked because it requires me an 8 digit code, please help !
  • Hi Khaled88
    Welcome to NETGEAR Community!
    An MEP code may be used to remove the lock, allowing SIM cards from any service provider to be used in the NETGEAR AirCard modem.
    If you would like to use your NETGEAR modem with a different service provider, you must obtain the NETGEAR AirCard modem’s MEP code from the service provider that sold you the NETGEAR AirCard modem.
    NETGEAR can't provide you with an MEP code.
    Blanca
    Community Team
1 Reply
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi Khaled88
    Blanca
    Community Team
