wilfredc
Nov 29, 2019Aspirant
Devices cannot inter-connect between 2.4Ghz and 5Ghz band
Hi All, I used my M2 MR2100 with the latest firmwire (NTGX24_10.13.09.00) to setup a small network in my car and there are a few devices connected to it including phones, laptops, a mobile NAS, a...
schumaku
Nov 29, 2019Guru - Experienced User
Appears there is a wireless isolation in place with the single-SSID configured. Either there is a control, or it's a bug...
wilfredc
Yes it could make sense if there are 2 separate SSID's and those under 2.4GHz are at guest network while for one single SSID it sounds like a bug to me. Hope Netgear can fix this in near future.
Just wonder if anyone with similar experience as I did or you have a different result.
Thanks!
