AML1618
Feb 27, 2019Aspirant
difference in Nighthawk M2 MR2100 & M1 MR1100
What is the difference between MR2100 & MR1100
- Mar 04, 2019
Hi AML1618
Thank you for your interest.
Nighthawk M2 Mobile Router (MR2100)
- LTE CAT 20, DL support up to 2Gbps speeds
- 3GPP, Rel. 14
- 5CA with 20 simultaneous Downlink layers
- 4x4 MIMO
- 256QAM DL / 64QAM UL CA 3C, 7C
- 11ac Dual band dual concurrent
Nighthawk M1 Mobile Router (MR1100)
- LTE CAT 16, DL support up to 1Gbps speeds
- 3GPP, Rel. 12
- 4CA with 10 simultaneous Downlink layers
- 4x4 MIMO
Blanca
Community Team
Blanca_O
Mar 04, 2019NETGEAR Employee Retired
Hi AML1618
- 3GPP, Rel. 14
- 4x4 MIMO
- 3GPP, Rel. 12
- 4x4 MIMO
Blanca
Community Team
Apollon
Mar 06, 2019Apprentice
Does MR2100 have a static DNS support, lacking in MR1100?
Will there be a US version anytime soon, with FDD-LTE bands B2,B4,B12 support?
- TeeJay74Mar 10, 2019Virtuoso
MR2100 DNS mode choices are 'Auto' and 'Manual'. I have not heard anything about US-version so far.
- ApollonMar 11, 2019Apprentice
I may have misspoken, calling dynamic DNS, such as No-IP, or dyndns.org "static", but either way your response has nothing to do with my question. Auto/manual DNS options are regular network configuration options, and not related to dynamic DNS feature I'm asking about.
Regarding US version - I was hoping to get a reply from Netgear staff, who would know for certain.
- nhantennaMar 11, 2019Apprentice
"Regarding US version - I was hoping to get a reply from Netgear staff, who would know for certain."
You would have to max out an M1's capabilities before an M2 is going to help at all performance-wise. I'm not sure that is possible to do in the United States at this time. Anyone out there getting the theoretical 1000Mbps download on an M1 in the United States?
Perhaps the M2 is cheaper to manufacture and then it would make sense for Netgear to replace the M1 in the United States from a cost perspective.
