AML1618
Feb 27, 2019Aspirant
difference in Nighthawk M2 MR2100 & M1 MR1100
What is the difference between MR2100 & MR1100
- Mar 04, 2019
Hi AML1618
Thank you for your interest.
Nighthawk M2 Mobile Router (MR2100)
- LTE CAT 20, DL support up to 2Gbps speeds
- 3GPP, Rel. 14
- 5CA with 20 simultaneous Downlink layers
- 4x4 MIMO
- 256QAM DL / 64QAM UL CA 3C, 7C
- 11ac Dual band dual concurrent
Nighthawk M1 Mobile Router (MR1100)
- LTE CAT 16, DL support up to 1Gbps speeds
- 3GPP, Rel. 12
- 4CA with 10 simultaneous Downlink layers
- 4x4 MIMO
Blanca
Community Team
nhantenna
Mar 11, 2019Apprentice
"Regarding US version - I was hoping to get a reply from Netgear staff, who would know for certain."
You would have to max out an M1's capabilities before an M2 is going to help at all performance-wise. I'm not sure that is possible to do in the United States at this time. Anyone out there getting the theoretical 1000Mbps download on an M1 in the United States?
Perhaps the M2 is cheaper to manufacture and then it would make sense for Netgear to replace the M1 in the United States from a cost perspective.
Apollon
Mar 12, 2019Apprentice
I disagree with you that I'd have to max out an M1's capabilities before an M2 is going to help - that makes no sense. M1 supports only 4CA, M2 supports 5CA. M1 has CAT16 LTE modem, M2 has CAT20. More carrier aggregation, and faster, newer LTE modem both will help with speed. Both, average speed and max speed attainable. Same way older phones with CAT6 LTE are getting much slower speeds in the exact same area than phones CAT12 LTE modems....There are several threads right here, on Netgear forums, where people who already have M2 say they get much faster speeds than with M1. It has nothing to do with utilization % of the max theoretical speed of the modem.
Blanca_O - you can run, but you can't hide.
- nhantennaMar 12, 2019Apprentice
"M1 supports only 4CA, M2 supports 5CA."
The M2 could have 5000CA. If you are not using all 4CA on the M1, the M2 will not go faster than the M1. The cell tower gives the same data pipes to the M1 and M2.
For example, your current cell tower supports 2CA. M1 negociates 2CA with it. That's the limit. Connecting a 5000CA M2 will not go faster than the M1 in this situation. In other words, you would have to use all of the M1's capabilities to the max before a M2 will help increase speeds. You have to use all the M1's tricks CA, LAA, etc to get that max speed.
It all depends on your carrier and cell tower. Where I live in rural United States our cell towers do not support CA yet (or LAA, or 5G, etc)
As for the faster modem in the M2, the M1 modem is plenty fast. 1000Mbps fast. We get 20-50Mbps in our area. An M2 is not going to help much here. But it still warrants a M1 vs M2 side by side speedtest. M1 vs M2 connected to same cell tower to see how they fare. Is the faster M2 modem 0-2% faster? 10% faster? If M1 vs M2 is that close in speed it is hard for normal everyday users to recognize that small speed difference. For example, a web page that loads 3% faster is not noticeable to a normal user.
"where people who already have M2 say they get much faster speeds than with M1."
to clarify, i am only talking about the united states. united states does not have m2 yet.
wireless carriers in other countries are wildly different than what you will find in the united states.
m2 may perform really well in other countries and terrible in the united states. only way to know for sure is to test the m2 where you live.
it must match up to your cell tower capabilities. if you do not have a 5CA tower, then you can't use 5CA on your modem.
- ApollonMar 13, 2019Apprentice
I'm network and software engineer, among other things, and really didnt need that 101 class, or any "cliarifications". In my area, my carrier just upgraded the cell towers in 2018 with the newest hardware available, and all towers here support multiple carrier aggregation. When I say "mulltiple" I dont mean 2 or 3 - I mean enough to max out all nighthawks CA capabilities. Your speculation that CAT20 LTE radio is only 2-3%, or even 10% faster than CAT16 is unfounded and incorrect. Look up LTE category specifications, specifically supported speeds, before posting.
Either way, I'm not interested in an argument, or even in a discussion - I posted in the thread with the sole purpose to have my 2 questions answered by Netgear staff (Hi Blanca_O , how you doin'? :smileylol:), not to get opinions/speculations from users. Would have used live chat support, in order to avoid exactly this type of "chiming in" from regular users, if Netgear provided one.
- phillipmcmahonMay 03, 2019Guide
Apollon you know YOU can always choose NOT to respond to "regular users" "chiming in". Otherwise you are only encouraging the silly unwashed plebs to engage with your higher intellect...
- BinnoJun 01, 2019Aspirant
For your kind info please the MR2100 has just been uploaded on the Netgear UK web site . Availability coming soon.
- mckenzieajJun 24, 2019Aspirant
In Australia you seem to be able to only buy the Telstra model. The firmware has removed the IP Passthrough (Bridge Mode) option. A frustrating step back from the MR1100. Hopefully this returns soon!
